Rocky Dyscmiester
- Jan 10, 2023
- 1
A little background, our volunteer group had a relatively new T3200, with Hydrostatic Transmission donated. When I picked it up, I was told I'd have to change the axel seals, which I did. They were very greasy, but no fluid leaked out. When I picked it up, it drove well onto my truck and at the park, it drove well, no issues. Since then the transmission did not go, even though I can hear the belts engaging. After changing the seals, it worked great. Then the next time we went to use it, no movement again. This model has no easy method of checking the fluid level. I've since removed the deck for better access, but don't see anything wrong. So it seems, at times, to fully engage and at others no engagement, but sounds right. What should I look at?
