7394
Might try Tractor Supply.I went to O'reilly's yesterday and could not find one brand with SM on the bottle.
Lucky me, Tractor supply sells it in 1 quart bottles.
The capacity is 1.5 quarts
It'll hone out...... ?If you look around I think you can find some SJ or SH spec oils in the implement stores and maybe in the lawnmower section. The Rotella T-4 oil seems to be fine for about any engine that doesn't call for the latest specs. But watch for "meets or exceeds" on anything you buy. Might wind up with a cylinder bore like this:
Might notice the wear is below the rings, piston itself is scoring the cylinder walls. Poor lubrication on the Kool Bore Briggs.
Cool, good to knowRight from Kawasaki website.
Ideal for all engines where API, CJ-4, SL and JASO MA oil is recommended.
Shell Rotella exceeds this standard in the 15w-40 T-4 oil. Read it on the back on any bottle.
- Designed to keep today’s high-performance, low-emission engines clean and operating at peak efficiency
- Protects against excessive viscosity decrease at high temperatures
- Manufactured with the latest additive technologies to provide superior performance
- Excellent shear stability assures stay-in-grade performance
- KTECH™ 4-cycle oil contains a zinc additive which prevents excess wear on engine parts.
