- Sep 5, 2014
- 5,170
Modern trucks that have the "Oil Life Monitor" on them, truth is: the engines can't tell if you run dino or syn, the monitor is calculated by run cycles. Most modern dino oils are very capable of going 5K or once a year.
The every 3K oil change was what was done in old days. Oils have improved greatly..
My truck has the OLM also, & I use M1 5w-30 (full syn) in it. Why ? Because that is what the book calls for it to run..
