Swapping wheels on a toro self propelled mower.
Madmax3089
Can I swap the rear wheels of a toro self propelled walk behind mower to larger ones?
semimechanicman
No you can’t do this. It is because if you change the wheel size, it will make the deck be un even as it is not set to be like that and the self propel might not work correctly if it is RWD.
upupandaway
In order to keep the mower level, you would need to bring the brackets off the mower you are getting the larger wheels from. This bracket will have the shaft higher to account for the taller wheels. You would need to make sure the holes to bolt them onto your deck and maybe need to carry over the handle.
With all that, it would be easier to just find a mower with the larger wheels if you really want it.
