SV600 blowing gas out the carb
Grasstobemowed
Family 9KHXS.5972GB
TYPE e11 *97/68SA*2002/88*0285*01
DISPL 597
MODEL SV600S
SPEC NO. SV600-0225
SERIAL NO 3928810723
BUILD DATE 10/15/2009
After a crank replacement I turn the engine over and all I get is gas blowing out the carb. I have spark and compression. I do not know how much because I just put my finger over the spark plug hole. I have replaced the coil because of a no spark issue. I now have spark(checked with a spark detector). Gas is getting to and through the carb(all though the wrong way). Does anyone have an idea what I might have done wrong? I also replaced the carb before the crank replacement and have never run ethanol through the carb.
Scrubcadet10
Moderator
Staff member
did you align the timing marks with the camshafts gears and crank gear?
Grasstobemowed
I found the problem. If you switch cams by accident because you were looking at the picture upside down then the compression release will open the wrong valve and push the gas back into the carb. Lession learned. Study those pictures better.
