SV600 blowing gas out the carb
Grasstobemowed
Family 9KHXS.5972GB
TYPE e11 *97/68SA*2002/88*0285*01
DISPL 597
MODEL SV600S
SPEC NO. SV600-0225
SERIAL NO 3928810723
BUILD DATE 10/15/2009
After a crank replacement I turn the engine over and all I get is gas blowing out the carb. I have spark and compression. I do not know how much because I just put my finger over the spark plug hole. I have replaced the coil because of a no spark issue. I now have spark(checked with a spark detector). Gas is getting to and through the carb(all though the wrong way). Does anyone have an idea what I might have done wrong? I also replaced the carb before the crank replacement and have never run ethanol through the carb.
did you align the timing marks with the camshafts gears and crank gear?
