12 757 01 is the gravity feed kit. Just used one today to fix a carb.Need a new Needle or carb repair kit.... All i can come up with is the Pump Feed kit.. I need one for gravity feed.
Thanks
TYVM, you just made this dummy a whole lot smarter.Here is the instructions that comes with the inlet seat kit.
Yes but as I said you are better just paying 3X for the inlet kit as too many of them here leak because of the seat itself is bad or at least that is my luck.12 757 01
