SV590-0220
Scrubcadet10
Moderator
Staff member
Need a new Needle or carb repair kit.... All i can come up with is the Pump Feed kit.. I need one for gravity feed.
Thanks
If you can't find it, that sucka' is gone!
The kit contain gravity fed needle valve. Now of course if you need the needle seat then you must order a separate kit and these do cause leakage.
Anyway I would order the 20 521 01-S kit instead if I was you.
Scrubcadet10
Moderator
Staff member
i guess the viton seat will go in.... this Carb uses the viton tipped needle.
Here is the instructions that comes with the inlet seat kit.
12 757 01
12 757 01 is the gravity feed kit. Just used one today to fix a carb.
Yes but as I said you are better just paying 3X for the inlet kit as too many of them here leak because of the seat itself is bad or at least that is my luck.
