Thank you very much. The Manifold tube was cracked. It runs fine now.Surging is lack of fuel or too much air after the fuel was added.
Take the blower housing off & check that the manifold tube is tight ( don't usually come loose ) and has no cracks in it ( very common ) .
Also check that the O rings that seal the carb to the engine are in good condition .
