I own a Craftsman riding mower with a Briggs 28M707 engine.
The sump gasket is leaking oil and I need to replace it.
Several questions:
- There are 3 different gaskets available (different thicknesses), I assume I should get the standard thickness .015"?
- Are there any gotcha's for this job?
- What's the torque spec for the sump bolts and the bolts that mount the engine to the mower?
- Should loctite be used on either the sump bolts or engine mounting bolts?
- Anybody know of a step by step tutorial for this job?
Thanks!
Several questions:
Thanks!
