FalconStig
- Jan 17, 2022
- 2
- 6
After 40 minutes of use my Craftsman Riding Mower (engine in rear) suddenly started to run rough and stall. It would restart and die immediately. Left it while I finished lawn with my walk-behind. After 1/2 hour, started rider again but continued to run rough long enough to get back to the garage. Replaced spark plug, fuel filter and checked oil level, fuel level and fuel for contaminants/water. No change. Carb was off and rebuilt at start of season. Was running great! Suspecting bad coil. Planning to replace coil but would like to know what VOM readings for a good coil to confirm defective.
Engine Specs: 10 HP
Engine Model 143.001000
Engine Family: YTPXS.3582CA
Displacement: 368
DOM: 0028A
Thanks for any info and/or advice,, Rob
Engine Specs: 10 HP
Displacement: 368
DOM: 0028A
