Stuck tire
I’ve had success with a mixture of kerosene and antifreeze. Was shown to me by my grandfather on the farm. Don’t know why it works, but you have to soak it for about 6 hours.
LOL soooooo on to my next installment of the process to fix this thing. After failed attempts to get the back wheel off, I started to look forward to where the clutch/ brake linkage connects to the peddle. As soon as I got this thing I noticed the clutch peddle was really far forward and difficult to reach. I'm 5'8" so I'm sure Craftsman (or whoever makes these things) intended for someone my height could use these and not someone 6'2". So I started thinking maybe there is an adjustment up front and no need to mess with the rear wheel at this time. I found two bolts under the clutch peddle and it looked like I could make an adjustment from there. I loosened the two bolts and tried to maneuver the plate behind the bolts as best I could (of course I have no idea what I'm doing) I started the mower, put it in gear and rode around the yard and I'm able the shift a bit better but, I don't have either a main brake or an emergency brake. I feel like I'm getting closer to solving the problem... I just need to get over the hump. Looking at where the clutch comes up from under the frame It seems to me that it should be closer to my feet.
If you can find an inexpensive replacement rim, you can always Sawzall the wheel to make a slit, then pry to widen the slit and pull it off.
As to your original problem. Have you checked the brake pads and cable / bar tension? Lots of mowers use a pad that wears, and when it does the belt geometry and behavior changes. Sometimes it will cause slippage, sometimes it will fail to brake the pulleys.
Trash? A mentor, who was engineer and machinist known for building winning Formula One and Indy engines, once suggested I try Liquid Wrench on some exhaust studs that were frozen solid. I laughed but tried it. I had already snapped one double nutted. Came back the next morning and all but one unscrewed by finger. The other one took a grab with a pair of pliers. Here is what Project Farm discovered in his testing of Penetrating Oils.
Now that is more believable when actually someone took time to do the testing head to head but just how rusty were the fasteners. And also proves that the home brew works better than most of commercial penetrating fluids. As shown heat is still the best for many applications. Probably why I still use a torch at times.
I give Liquid Wench a try as there got to be something that actually halfway works but I won't be holding my breathe until I prove it myself. I have had to use Muriatic Acid on steel on steel and Sulfuric Acid to remove steel fasteners out of aluminum. And I have even used Sulfuric Acid to clean some carburetors.
Whatever anyone does DON'T use Muriatic Acid on anything aluminum or you won't have it long.
Thanks for the heads up on Kroil I'll pick some up the next time I'm at Lowes
I can't prove by it my results and that's what counts to me....Of course people swear by JB Weld too and I have try them and they fail to live up to hype.
Taryl gives ideas....https://www.lawnmowerforum.com/threads/stuck-tire.80470/?utm_source=email&utm_campaign=trending
Regarding whacking the backside of a rim with a hammer, angle iron, or whatever to break it loose from the hub, I did that one time, and instead of the rim breaking loose, the retaining ring on the tip of the axle rod in the gear inside the transmission pulled out of its groove - so the entire axle rod-hub-wheel assembly slid out of the transmission. 😱 So I had to partially disassemble the transmission to retrieve the retainer ring and put a new retainer ring in.
