- Nov 29, 2014
- 64
- 24,647
The F-N-R lever should only be used when the mower is stationary & the clutch/bake pedal is pushed in.
The "gears or speeds" are nothing more then notches that prevent the clutch /brake pedal returning to it's full height .
This changes the tension on the belt which changes the position of the sliding sheave on a double pulley which naurally changes the relative diameters of the pulley.
In princile exactly the same as the stepped pulleys on a pedistal drill or bench lathe.
