- Feb 19, 2020
- Threads
- 121
- 12,884
Yes compression your gauge is not design for this smaller engine. And if you are only getting 45psi on the mower it is definitely not reading right as even 4 cycle walk behind mowers with compression release needs to read at least 65-70 psi. Two cycle equipment must operate at a higher compression in order to ignite the fuel mix as it has higher ignition point than straight gasoline.
Just trash or recycle that unit as parts are no longer available for that 25cc unit. You couldn't repair it if the PNC is bad. Most of the other parts are also NLA. Now the carburetor may still be rebuilt but a new one out of the question.
What to do is try a little fuel added to the cylinder and see if the trimmer engine will try to run. If it does then it is carburetor problems; otherwise, it is compression or ignition timing which would unrepairable due the lack of replacement parts.
