Stihl TS-460 cut of saw
bogdaN
Need some help how to remove carb.Carburator is leaking i find gas in intake pipe,that have to be fixed.I order torx L shape,but still that bolt on right can get it.
You must remove the carburetor before you can remove the intake manifold.
bogdaN
That was easy when you know how.Thank,s StarTech.I will report when i finish job.
bogdaN
Here is what i found-open up carburetor everything was good ,just fuel inlet lever was to low-make small adjustment. Installed carb,and start testing.I should mention that also new piston & rings was installed.Pull starter few times and got big kick back--what i found was sheer key in flywheel.Fixed that and she is back running goood.
