Here is what i found-open up carburetor everything was good ,just fuel inlet lever was to low-make small adjustment. Installed carb,and start testing.I should mention that also new piston & rings was installed.Pull starter few times and got big kick back--what i found was sheer key in flywheel.Fixed that and she is back running goood.
