Stihl Ms-180c Help!!!
Kodie's Lawn Service
I bought a ms-180c aftermarket cylinder kit an installed it the saw will run high rpm all day long the only problem I have now is that it will not idle I have tried to adjust it an now change any idea what it might be???:confused::confused::confused::confused:
exotion
Time for the carb to get cleaned
Idk never tried that I will here in the next couple of days an let u know
Re: Stihl Ms-180c Help!!
No, air leak test.
Hold on, go back. Why did you replace the p&c? Was the saw yours before or did you get it burned up?
I burned it up an wanted to fix it should I re do the silicon gasket on the bottom of the motor an also how would I test that
