Hello,
I bought last year 2 hedgetrimmers STIHL HS82 - the "T" and the "R" version. They do good, only I see and hear that 1 of them, the "R" is running too rich because fumes , sound and more oil coming out of the exhaust.
I went to 2 Stihl-dealers here, but both don't seem to be able to adjust the machine as I wish.
I checked how many turns the "H"-sscrew was screwed out on both machines. The "R" had 2.5 turns out and the "T" had 2.1/8" turns out.
I have set the H also at 2.1/8" on my "R"-type and thought that then they would be the same, but I see that the "R" is still running too rich.
Then I asked STIHL-Belgium what the factory settings are for the hedgetrimmer HS82, they replied: turn H and L-screw both 1.1/2 turn out. Then turn the rpm on the L-screw as low as possible and the H-screw as high rpm as possible.
I know that the HS82 has a speed-limiter (9300 rpm) - so when I turn the H-screw it is difficult to hear because of that speedlimiter. I have also a tachometer.
Can somebody explain to me HOW I CAN SET THE H-screw CORRECTLY ON MY 2 HEDGETRIMMERS HS82. Both machines are the same when you only compare the motor. I can use my tachometer eventually.
HOW TO DO IT ??
Thanks for your technical advise.
HOW TO DO IT ??
