EngineMan
 - Jun 12, 2012
- Threads
 - 9
 - 2,275
My brothers fs400 runs well until it gets to about half a tank of fuel, then it stops, its had a new coil, new plug, fuel tank is clean, new fuel filter, new air filter, fuel pipe's are good new fuel bulb and the carb cleaned and fitted with new carb kit, again it will start OK and then die after half a tank of fuel (it seems) I have been working on engines for over 40 years but this one got the better of me, any help on this one would be welcome.
when it does stop if you remove the plug it is dry so its fuel related..!
Wiring from the switch to the coil is like new and find no problems, had meter on the kill switch no problems there.
I am happy with the job I done on the rebuild carb but I have ordered a new carb and fuel pipes to see...! its on its way and will be here next week, I'll keep you all posted.
