- Nov 29, 2014
- 64
- 24,705
Well you fix the fuel lines by replacing them with longer ones to get a better run.
Chokes can be swapped over
If you have a choke on the air filter housing then remove the choke for the carburettor and plug the 2 holes the shaft goes through with some metal filler .
If the old carb has a butterfly choke then swap them over , it is just 1 screw & a circlip .
