- Nov 29, 2014
- 24,995
Farmer Teck is the retail outlet for the company that makes OEM parts for a lot of factories that assemble big brand chain saws.
The same parts are sold by all of the after market parts suppliers and come with full warranty so are usually good quality.
So if it came in a package labled farmertech it should be in specification.
The stihl service chart says 3 turns out for both needles but that will be for a newish head with EPA compliant carb as they have finer tapers, thus more turns.
The service manual I have specifies 1 turn out on both needles.
Check the impulse holes, they must be clear so the pulses can work the fuel pump.
Stihl used a few different carbs on the 120 heads and I can not remember if they all had impulse hoses or just holes in the manifold.
If holes in the manifold make sure the gasket is not blocking the hole off.
Pull the carb off, turn it sideways and blow low volume low pressure air through the venturii .
You should be getting fuel out the other end .
bes trick is to turn down a compressor then use an air duster inside a dunny roll centre.
And finally about the seals.
They have to be airtight in both pressure & vacuum, looked good does not cut the mustard they have to be tested.
Check Joe Pace Two stroke diagnosis on U tube.
The problem with most of the repair videos is the tech already knows what the problem is so just shows you how to fix it rather than how to find it.
