Magnets slowly die over time
Heat & mechanical damage will hasten this .
Over time I have found that if it throw a spark without the plug but won't throw a spark with the plug, then the magnets are gone
The caveat to that is trying the coil slightly too close and making sure the plug is the right grade, resistor type & gapped correctly .
To verify I have a sliding gap tester so if It can be started I just keep on increasing the gap till the spark stops
1/3" or more is OK
1/2 " or more is great
Less and it wont throw a spark inside the engine.
1/3" or more is OK
