Hey Dan.......... What you gonna do besides Hey I'm from LA and I have a blower that runs good, but I'll be back in a week or so if it goes out ... LOL Are you from LA ????
I am but not Los Angry and Lower Alabama, but Louisiana......... I have spent some money in Bayou La Batre though,,, I had a bar room there ....
You have 2 adjustments on your carb if i'm right .......... L and H jet's ..... When you soaked the carb was your metering diaphragm still really soft or was it stiff ???? That makes a world of difference .... Also the pump side diaphragm should be in order....
Go ahead and see if you can locate the fuel filter in the take and check it.. Those should be changed once a year....
Does it run on choke pretty good ??? Or half choke ???
Let us know Mon Ami ~!~!
Hi from Connecticut and welcome to the forum. I'm a landscaper who obviously has heavy reliance on blowers. So I'm not one of the experts here but I've picked up a thing or two about getting and keeping small engines running.
Soaking the carb may not be enough. Sounds like you may have a plugged jet. You can strip a twist-tie and use the wire to carefully ream it out. Do you have ethanol in your gasoline there? I've had equipment accumulate an ethanol/water emulsion in the bottom of the tank during storage that fouled the fuel filter. And yes it should have one inside the tank. I hook the inlet line with a bent wire. I'd certainly replace it. I always replace the plug too for any starting/running issue rather than clean them. The first thing I do is dump fuel and replace with fresh, clean/replace air filter, replace spark plugs, clean the carbon from the muffler screen (I hold with pliers and torch with a lighter then brush off) and replace fuel filter. It's all about eliminating potential causes.
The mechanics here can offer a lot more detailed diagnostic info to help you get your blower running. Several make their daily rounds here.
Part #28. I may not have it anymore. PO may have taken in out already.
Hey Dan..... La. here again......... This is a buddy of mine in this video.... He is a Stihl dealer and Authorized service center for Stihl........ BTW your metering diaphragm looks hard to me, that's the one that looks like a wagon wheel..........It's not doing it's job and causing the flooding from the carb that you see...... This vid will put you at ease ............
Enjoy Mon Ami ,,,, https://youtu.be/7-VpdJEJRRw
Dan,
what you have done is fallen for the newbie mistake of ripping everything apart before you took the time to actually work out what was wrong.
Thus you have the original problem to contend with plus any / all of the problems introduced by yourself in ripping things apart.
Back in my original response I suggested that you try running it without the muffler .
So your only problem could have been whatever is inside that 1 lb muffler that is making it weight 5 lbs.
Next you have fuel pooling on top of the tank,
So you now have a fuel leak that you did not have before you started to fix the blower.
The fuel tank & carb are a low pressure, pressure vessel and run at around 5 to 10 psi.
If a fuel line has a leak in it or the grommets in the fuel tank do not seal or the carb is not airtight or the vent is not working or the fuel cap is not working, then the blower will start but not run for long.
There is a logical proceedure for these thongs and that is to start from the beginning, the fuel tank.
If it holds pressure and can also suck in air then chances are it is ok.
The next thing you do is block off the return line dip the carb in a jar of water and pump the inlet line.
You can just blow into it.
If all is working OK there will be no bubbles.
If you have a pressure tester with a gauge, the carb must hold 10 psi.
You will read all sorts of trash about "pop off pressure , ignore it. Forcing the fuel needle to lift off it's seat by applying too much pressure to the fuel intake tells you nothing other than you have been led down the garden path by a shaved monkey with less idea about what he is doing than you had before you started.
Now that the carb is apart, clean it and DO NOT BLAST HIGH PRESSURE AIR THROUGH ANY PASSAGE. All that does is jamb debris so hard into tiny holes it can never been dislodged.
Skip the beer.
Anyone who touches an engine after drinking either has a bad booze problem or is an idiot.
Sorry Bou, I know Steve is a friend of yours and I know he knows a lot by what he says, but beers are what you have when you have successfully fixed your equipment and kocking off a few tinnies while you are working will not help the outcome one tiny little bit.
