Go to the Walbro web page.
Hidden in the bottom right corner on the cube carb page is a link to their service manuals and even a couple of videos.
Nothing hard about them except they need to be clean and when you work on them you need to be clean and the area needs to be clean enough to conduct open heart surgery in.
I do it in the workshop bathroom.
Get a diaphragm kit for you carb , should be around $ 10 (US).
Despite all of the fertilizer you see on U-Tube always replace the diaphragm & gaskets, they are very cheap and telling the difference between a good one and a not quite so good one is a difficult job.
Your problem sounds like either a clogged exhaust or clogged high speed jet.
Inside the carb is a little screen which gets bocked.
When left unused for long times fuel can leave gum inside the tiny holes.
However before you start, loosen or remove the muffler and try again.
If it runs then your muffler is blocked.
On the fuel tank there are 2 fuel lines.
One is the outlet & the other the return.
Pull then off at the carb, after tanking photos or lableing them then blow gently down the filler cap.
Fuel should flow out of one of them .
Put the cap back on. Pinch off the one that did not flow fuel and leave the tank in the sun.
Fuel should start flowing out of the outlet tube as the tank gets hot if the filter is clean enough to be used.
If the muffler and the fuel tank check out OK then time to pull the carb down.
And don't forget the most important tool in the box, your camera use it every time you remove any part.
