This brushcutter starts and runs but wont idle and has no power. The only way I can keep it running is either by continually triggering the throttle, or slowly open the throttle to about 1/3 and hold it in place. From there it will run (sort of) but produces no power and will not rev out. The power is insufficient to even engage the clutch.
The motor does have compression and spark.
There was some water and contamination in the fuel tank and so all fuel was replaced with new.
Carb, filters (Fuel & Air) hoses and spark plug have all been replaced with new parts.
Even with those parts renewed the running symptoms remain unchanged.
Ideas from the Sthil brains trust would be appreciated.
Thanks in advance.
Thanks in advance.
