Steering Wheel
loyce
I want to replace the stock steering wheel on my John Deere LA 145 with a larger one. How do you remove the one on the mower now and can a larger one be added. Thanks
KennyV
Take off the center nut and pull the wheel off the splines on the steering shaft....
If you find a wheel with a similar ID and thickness, just press it on and re[lace the nut... :smile:KennyV
