Steering Rod Bushing
LT2000
Need some help locating some (2) bushings for the steering rod on my LT2000 Craftsman Mower. Thanks in advance. I have pictures but they are too big to upload so if you need to see what I’m talking about let me know and we can figure out how to get them to you.
open you photos on your computer in any app that will read & display them
Change the size to 12" on the longest side & the resolution to 72 DPI
Then save them in jpg format
Thuse will upload and display full size on a computer .
Phones store inRAW format so they can get good detail and write the file quickly
Web hosts see a RAW format image abe being near 10 times the size it is ( number of pixels type of size )
give us the model number so we can look up the part, several manufacturers may have made that LT2000, the model will either be on a sticker under the seat, on the bottom of the seat frame, or on the reverse side of the hood,.
Also post the model number from the serial number tag. LT2000 was produced by both AYP (Husqvarna) and MTD. Also which rod are you referring to, is the one between the two front spindles (AYP/MTD version)?
Edit: Probably what you are looking for is the cross draglink bushings which should be PN 532126847 (Rotary 7279). Now id is 3/8" (rod size) 17/32" OD hole size.
Thank You! I appreciate the support. I ordered a few and will be here on Friday.
