logistiker
- May 2, 2012
- 5
- 26
I've come up with a fix for steering problems related to the Rechargemower G2. I have had two different model numbers of this mower that exhibit the same problems with steering. If you push down on the steering column and turn all the way in one direction (all the way left seems to be the worst) and then try to turn back in the other direction, the steering will make a clicking sound, the wheel will spin freely and the wheels will not turn. After some trial and error, I determined that the problem was that the two gears were not lining up properly because there is too much give between the shaft and the tie rod assembly. The fix essentially consists of inserting 3 washers under the nut of the shaft rod but it requires removing a bunch of parts to get to it. I am attaching some pictures to show the process.
1. Unscrewed tie rods
2. Removed steering assembly nuts
3. Removed battery indicator wire (Noted where the wires plug in on the battery level indicator before removing them)
4. Removed cover, steering wheel and steering wheel assembly
5. Removed plastic cap on steering wheel assembly and noted the gap between the nut and the gear
6. Noted the shaft gear out of alignment when moving the shaft up and down
7. Noted the shaft compressed before the fix
8. Noted the shaft extended before the fix
9. Found three spare washers to put under the nut.
10. Reinstalled the nut with the washers underneath.
11. Got a closeup of the fix with the washers.
12. Noted new extended shaft length.
13. Noted new compressed shaft length.
14. Reinserted plastic cap and reinstalled all parts.
4removed_cover_and_steering_wheel_and_steering_assembly.jpg220.8 KB · Views: 19
5removed_plastic_cap_on_steering_and_noted_nut_and_gear_gap.jpg243.7 KB · Views: 18
