I have a 22 hp v twin briggs 4o7777, it has a electric pt , Ive checked the out put on the stator and I can't get any more than 24 volts out of it and only 12.5 out of the regulator...........the battery is holding at about 12.5 to 12.7 enough to keep it starting ......I have used the deck only once to cut my lawn after i put in two new spindles and bearings in the other ... along with three new blades........it is now sitting and covered up...... I'm reading that I should be getting a minimum of 31 volts ac out of the stator and up to 14 out of the regulator............ both are low numbers.............do I need to buy a 16 amp stator and new regulator ..........or will the stator salve the low output on the regulator ?? |
