bobknowverylittle
 - Jul 18, 2025
- Threads
 - 2
 - 17
Snapper Pro S200xt, 49E877 vanguard engine EFI system. As mentioned, engine bogs down when turning on the PTO. Just started doing that two cuts ago. Turned off engine to check for debris and or bad pulley, they were fine. Started engine again and problem went away, cut grass. Same thing happen again following week, again stop and restarted engine and all worked fine. This week problem has come back and is not going away as before. Plugs have only 28 hrs. , all pulleys were not hot to the touch. Any suggestions on what to check? M.I.L. comes on and then off again, just not getting full throttle when PTO engaged.
