- Nov 29, 2014
- 24,995
no one is having a shot at youits okay dude i had the same issue about people telling me " GET YOUR SERIAL NUMBER" and i would never listen lol
However engine makers change specifications all the time
Download any Briggs parts book & you will see multiple parts changes over a model run.
Add to that 17 Hp tells us absolutely nothing we need to know which on of the 4 different 17 Hp engines he has.
When aa new engine gets released there are always teething problems so it helps us to know if the mower has for instance an oil flow problem as happened with the current 7000 series.
17 Hp Courage engines before a particular date had problems with the crankcase screws loosening and they have adjustable rockers
Where as the 17 Hp Command engine has hydraulic lifters & a different crank case and crank for that matter.
