Item 935 is the kill switch its on the control bracket (carb)
Thank you. It appears that is not tripped. Since it fires up each time I clean the carb, do you think the carb is bad or what else?
If it runs after you have clean the carb, then it looks like fuel, clean out the carb again and this time the fuel tank and lines.
What's the best way to clean the fuel tank and the fuel line?
