ARN Greencare
- Jan 11, 2019
- 0
- 15
I hate B&S products.
Probably it will need nothing more than a clean or a new solenoid.
Your engine manual will explain how to test & repair it and that is a free download from Kawasaki.
Put the starter back in but do not hook it up
Put your car ( or your car's battery ) next to it.
Run a jumper to the heavy + terminal on the starter solenoid and the other jumper lead to a good ground on the engine case.
If hooked up right, nothing should happen.
Now with a bit of hook up wire bridge the + terminal to the terminal where the yellow wire went.
If the engine cranks over normally, the starter is good.
Now do the exact same thing using the mowers battery.
If the engine cranks over normally the mowers battery is good.
Hook up the starter to the mowers wiring .
Leave the jumpers in place
turn the key
Engine cranks normally = starting circuit is good
Remove the ground jumper lead
Engine cranks over normally = ground wire is OK
Remove the + jumper
Engine cranks normally = power wire is OK
Because they are exposed to the elements, the power & ground cables on ZTR's suffer from corrosion.
I clean up the contact areas, bolt them up tight on a hot day in the sun so the connection is dry then paint them with liquid electrical tape to keep moisture out.
This includes the exposed ends of the battery leads.
Moisture can wick down the wire from where it is exposed then corrode the wire inside the insulation.
When you test a lead like this, it shows 0 ohms but when you try to push amps through it all it does is generate heat.
On a really damp place like Hawaii consider replacing both battery leads with tin plated marine cables and still slap the liquid electrical tape over all exposed contacts.
The stuff peels off really easily but will keep the area dry & prevent corrosion.
