Starter problems Ace riding mower
ex hooker
Older Ace riding mower. Starter spins when ignition on but doesn't engage with the flywheel teeth. Installed a new starter and same problem. Thanks
Welcome
To help you, you need to help us
Engine make & model numbers please
This may sound crazy but make sure the battery isn't connected backwards. negative to positive and positive to negative will cause the starter to spin backwards and won't engage the bendix because it is turning backwards. Can cause other electrically issues on some riders,
