Starter on Re rider
Lucky1313
Anyone know where i can get a replacement gear
any mower shop should be able to get it for you if you look on the B&S web site you may find it also but you will need model number of the engine
Like Scott said take all your model numbers to any good small engine shop and they should have them in stock or at least can order you a new gear. That is all you really need, but by the way it looks I would replace the entire drive with a kit.
Go to napa tell them what you want give him $2.50 and your good to go
All you need to do is tell him the engine you have
Sent from my iPhone using LMF
Yep found the kit i have no model numbers so it was a little harder so just a guess but it comes next week we will see
