Anyone know where i can get a replacement gear
L Lucky1313 Member Joined Apr 6, 2012 Threads 5 Messages 28 Jul 1, 2012 / Starter on Re rider #1 Anyone know where i can get a replacement gear Attachments image-2023728586.jpg 386 KB · Views: 20
L Lucky1313 Member Joined Apr 6, 2012 Threads 5 Messages 28 Jul 1, 2012 / Starter on Re rider #2 Lucky1313 said: Anyone know where i can get a replacement gear Click to expand... Also its the 11 hp B&S
scott47429 Well-Known Member Joined May 29, 2012 Threads 22 Messages 646 Jul 1, 2012 / Starter on Re rider #3 any mower shop should be able to get it for you if you look on the B&S web site you may find it also but you will need model number of the engine
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 59 Messages 15,280 Jul 1, 2012 / Starter on Re rider #4 Like Scott said take all your model numbers to any good small engine shop and they should have them in stock or at least can order you a new gear. That is all you really need, but by the way it looks I would replace the entire drive with a kit.
Carscw Lawn Pro Joined Aug 11, 2011 Threads 66 Messages 6,375 Jul 2, 2012 / Starter on Re rider #5 Go to napa tell them what you want give him $2.50 and your good to go All you need to do is tell him the engine you have Sent from my iPhone using LMF
L Lucky1313 Member Joined Apr 6, 2012 Threads 5 Messages 28 Jul 3, 2012 / Starter on Re rider #6 Yep found the kit i have no model numbers so it was a little harder so just a guess but it comes next week we will see
