pipeproducer
- Jun 28, 2020
- 5
i have a 2008 john deere 22hp briggs engine. bought it used. starter went out right away. the ring gear ( plastic) was worn down on two oposite sides on the lower part of the ring gear. ordered a new one and installedit. ordered a new startyer and put it on and stripped out the drive gear after starting it up 6 times. bought new starter drive gear and installed it and only lasted three starts. stripped the gear. bought these parts on ebay, the mower is an la145 rider. there is no adjustment on the starter so i dont understand whats happening here. 16 tooth drive gear. it seems to mesch ok with the ring gear okay. someone said the valvea need to be adjusted. dont know what that has to do with it. it has about 413 hours on the mower. thanks rich
