Starter bolt stripped.
Fish
No, if that is for the same size the old bolt was, or was your old one metric?
Just tap in the tap, keep the direction straight/perpendicular.
LaWn GuY
I bought this can I put the threader on to my drill and use It like that?
Carscw
I bought this can I put the threader on to my drill and use It like that? <img src="http://www.lawnmowerforum.com/attachments/tecumseh-engine-forum/22637-starter-bolt-stripped-20140808_220046_android-jpg"/><img src="http://www.lawnmowerforum.com/attachments/tecumseh-engine-forum/22638-starter-bolt-stripped-20140808_220128_android-jpg"/>
You can put it on the drill but it will break.
Use a wrench I think 5/16 turn it in a couple turns then out then back in a couple more.
motoman
Unless you drill deeper or drill to next oversize a tap will probably only clean out a damaged hole. Same size deeper is risky-make sure there is material available without hitting somthing . Drilling for the 1/4-20 (consult a tap chart for drill size) you have is likely to wipe the few remaining good threads you have unless you center the piece in a vise and lock it down. I guess you are going freehand since the engine is not apart. A problem (likely) will take you to the helicoil. Try using a square to keep the drill vertical or you will not obtain 360 degree clamping under the bolt head and your fastener will break due to flex/work hardening. While this may seem simple it is not to get it right. Consider a local machine shop.
LaWn GuY
Thanks everyone but I only had my drill with me and everything turned out perfect.
