Standing a mower up
There is a bar at the rear of my zero turn. Is there any reason that I couldn't sleep and anything up on its rear? It would make it easy to change the blades and clean underneath the deck.
txzrider
snapper riders(or at least mine was) are designed to do that.. but the oil fill tube is in the back of the mower to allow it.
txzrider
Then I would look at your owners manual, it will state if it is possible to do it, if no mention then I would not.
Assuming that I cannot… What is the best way to get under there? Car ramps?
metz12
or put it on car ramps? then put a cinder block behind a wheel just encase it doesnt roll back on you.
In our shop we just put a car jack under the front of the deck and raise it up. Do it everyday with no problems.
Couldn't find anything in the manual so I emailed gravely. They said do not stand it up on its rear
