stalls when clutch let out or when pto put in forward
dunaprop
  • / stalls when clutch let out or when pto put in forward
checked all safety switches ,gas flow, replaced pto cable not moving ,belts seem to be tight and turning,engine starts and runs fine....but let clutch out stalls or let pto to forward stalls.....what gives?.....linkage?....
dunaprop
oh troybilt tb 30r
dunaprop
oh troybilt tb 30r
checked harnesses and wirind looks good....maybe i measure pto switch and trans brk....they seem to work ,,,measured seat switch fine......dont know what else?...grounded out somewhere....harnesses look good....
Safety switches
Seat + parking brake + magneto
Seat + PTO + magneto
See some thing in common here with your problem ?
Good chance it is the seat switch or the wires going to or from it .
Seat switch connector has a shorting strip in it. If connector is not fully plug in or the shorting is damaged, It would be the same as if you were not on the seat. Also note the there deck attachment switch that could be the problem but not in this case
