oh sorry man - I wasnt aware you responded until now.
pictures might be better to explain:
throttle incorrect postion:
see how the boom a rang shaped throttle has slipped past the governor block.. it's past the block to the right.. it has to be behind that stop block to work properly:
now here it is in the correct position behind the block:
I also removed my carb and when i put it back together is when I finally noticed this after looking at some other pictures of the carb installed online.
hope this helps.. it's all that was wrong with mine.
PUsh
Again, I appreciate the conversation and the pictures. All is correct in my linkage and install. I called my local repair tech and he thinks the intake tube may have cracked or separated at its mount allowing some air leak. I am going to look this over as soon as this weather warms back up. Thanks again.
