Stall- kohler courage 19 - move throttle past notch and it stalls
kevicarlson
  • / Stall- kohler courage 19 - move throttle past notch and it stalls
I still have the issue that when I move throttle past the notch or middle it will stall out.
This is a kohler courage 19 sv590-012 on a ryobi riding mower.
What carb adjustments might I need?
Carscw
Is the notch about 3/4 of the way to the top?
On the ones I have had all the way up is choke and run is in the notch.
Sent from my iPhone using LMF
Carscw is correct, by moving the throttle you are choking the engine, making it run rich.
kevicarlson
I managed to find the mowers owners manual online.nitnindictes that top throttle is "fast". I suspect then that it should run at that position, I need to work through carb adjustments I suppose?
Carscw
So you have a choke knob you pull out to choke Ot on cold start up ?
possum
Pull of your air filter. Observe the choke as you work the throttle with the engine not running. This should show you if the choke has a malfunction or the operator has a malfunction.
