ssshelton1
- Aug 8, 2014
- 1
- 2
This Echo Trimmer will not spin fast enough to cut grass, It runs fine just really slow. I have practically re-built the entire fuel system and carb. What am I missing?
Turns out that removing the exaust and scraping out the Carbon Build-up from the motor, fixed it!
Using the new echo"powerfuel" canned premix will help clean out the carbon from the engine as you use it, and free up stuck piston rings. good luck.
The problem of carbon is not rly the gas, its the burning of the oil. Cleaning the exhaust port is good regular practice and I believe echo and other 2 cycle manufacturers should include it in there regularly scheduled maintenance and manuals
