Springs for my MTD mower
Pctriple
Hi all thanks for sporting me to the forum. I'm after the spring configuration for my MDT mower looks like it's missing 3 small springs,here is some info of the mower it's self
MTD backline BL4046
11C-J10G683
CD221T2142
Fuel tank 11 0221 51 93618
Engine family BBSXS.1581VG
Briggs&Stratton 450 series 148cc
Any help in keeping this running would be a massive help.
Many thanks
Paul
First, please check that you have the correct model number posted for your mower. I can’t find a 11C-J10G683 model. Second, may I ask what springs you think you are missing? Is it mower or engine? Third, if it is engine, please post engine numbers or a picture of the QR code box on the engine. You must realize that we aren’t standing next to you to see what you are talking about.
Thanks for your reply. I'll have a look and upload some pictures. The spring are off the plastic carburettor and a control lever close to the inlet port. There should be three small springs but I can't find anything anywhere regarding parts
Having trouble posting picture atm . The springs are linked to the carb' 2 for the throttle and 1 for the ignition advance level also linked to the carb'
Is there a online parts catalogue so I can see if I can get the arrangement correct.
Thanks
There is only two springs and a linkage rod.
201 690347 LINK, Air Vane
209 690254 SPRING, Governor
211 691859 SPRING, Governed Idle
