- May 6, 2010
- 12,007
One the first notch down the deck should move rearward to tension the belt, and then not move backwards since the deck belt should be tight and then the deck should just move downward as the deck is lowered. There may be an adjustment rod connected to the lowering lever that will change the point that the belt tightens.
