SPLITTING ENGINE HELD TOGETHER WITH HONDA BOND
honda1
hello I have an HRR216 VKC that I have to replace the governor that's malfunctioning but how do separate the 2 halves of the engine that are held with that HONDA BOND after you remove the bolts?
thank you in advance
Here's how to pop the block from the oil pan, and how to get them back together again:
Just what is Honda Bond. anaerobic sealant ?
More them just Honda uses anaerobic sealant. Been using it for years where a gasket wouldn't work because of clearances like putting cases together. It sound like they just put there name on it and call it Honda Bond so they can charge you more for it.
Hondabond HT is "...high temperature silicone liquid gasket. Non-acidic, will not corrode aluminum For use in areas not requiring solid gaskets." It comes in a 1.9 ounce tube with a list price of $16.28. Honda part number 08718-0004. Google any part number to find a Honda Dealer selling it online, or use this link to find a Honda Dealer in your area: Find A Honda Dealer
The Honda shop manual says you may also use Loctite 5900; "Flange Sealant, Heavy Body RTV Silicone is a one part RTV silicone that has superior flexibility and adhesion. Provides instant seal. Excellent fluid resistance. Non-corrosive, low odor, low volatility." A 300ml (10 ounce) tube is $46.05. Loctite part number ORS091220166ORS.
