i have a briggs & stratton, mod. 385777 type 0349 e1. it will start & run fine most of the time, then it will stop firing on 1 cylinder. yesterday it ran fine for about an hour & half, then when i took a break it started skipping on 1 cylinder when i restarted. when i checked the fire it wouldnt arc to the plug & only arc about a 1/16 to 1/8 inch to ground. just installed new coils. any ideas as to what the problem is??
