Ihategrass
- Jun 6, 2021
- Threads
- 2
- 5
Hi Everybody,
At the end of last season I serviced my ride on before storing it for the winter. The 12.5 flat head engine is some 20 years old and still had the original Briggs spark plug. I changed the plug for a new one. The local store sold me an "ALM 19" showing me that their interchange stated it was the direct equivalent.
At the start of this season it would not start and backfired constantly through the carb. Eventually, to sort the problem, the engine was completely torn apart and rebuilt. It still backfired through the carb.
I tried advancing / retarding the cam and the ignition and cleaned the carb until it was almost worn out. Nothing seemed to work. After weeks of messing about I reverted to the factory settings and installed the old plug. It ran like a sowing machine!
Bottom line? It seems the Magnetron ignition system must have a resistor plug to work properly (for my engine the reference is RJ19LM). The ALM 19 plug is not a resistor type despite what interchanges may say.
Don't know why the two types should make such a huge difference as both will show a very healthy spark at the plug tip but a substitution leads to a world of pain!
For ref my new replacement plug is an NGK BR2-LM and the engine starts and runs perfectly. Looking on the bright side, learnt an awful lot about this particular engine and mine is now fully reconditioned.
Hope this might help anyone with a similar problem.
Len
Len
