Spark plug replacement on Craftsman Lawn Tractor
jimvt
Someone kindly sent me to the spark plug replacement site to check out a replacement for a TorchF6RTC plug.
The suggested replacement seemed to be Champ. RN11YC.
I ordered that from Kohler (thru Home Depot) and they sent me Champ. RC12YC.
Will that work?
Thanks,
JD
pugaltitude
Yes it should work not a problem.
The RN11YC crosses onto an NGK BPR5ES which is the about the same plug as the champion RC12YC.
Ric
Will that work?
Thanks,
JD
Here's a site to cross Spark plug cross reference
The Touch F6RTC crosses to the NGK-BPR6ES according to the site
According to the site the NGK BPR5ES crosses to a champ RN12YC4
[h=3]Possible spark plugs for torch F6RTC:[/h]
According to this site there is no cross to a champion.
jimvt
Oh, Boy...two replies...two opinions.
Maybe I should ask if the RC12 would do any damage to the mower?
Carscw
The rc12 will not foul out if you run a little rich
(( racing is the only sport that you need two balls ))
Ric
As far as damage to the mower I couldn't really say but seeing how the F6RTC doesn't cross to a champion according to the site I personally wouldn't be using it in my engine. I mean why would you take a chance when you can go to some place like Auto Zone and get the NGK- BPR6ES which is the direct replacement and have the correct plug, personally IMO a better plug than a Champion.
pugaltitude
What engine is fitted so that you can get the right plug fitted?
Ric
If the spark plug came in the engine from the factory wouldn't you think the F6RTC would be the right plug?
pugaltitude
If the spark plug came in the engine from the factory would you think the F6RTC would be the right plug?
Iv never heard of this plug or seen it used in any engine manufacturer.
I only go by what manufacturer recommends.
Iv never understood this thing of NGK are better than Champions but Champions better than Denso
etc etc.
Briggs use champion, Honda Denso or NGK, Kohler use Champions, Kawasaki use NGK and Tecumseh use Champion and NGK.
Imo a plugs a plug just different heat range and lengths etc.
If its a Kohler engine as the op bought from Kohler the RC12YC will be the correct plug.
Carscw
The tv show hot rod tv did a test all they changed in the engine was the plugs out of 10 plugs the only one that had a HP gain was acdelco
Did same test with oil and every oil had deferent HP
