Spacing spindles with washers?
whitepony04
Star hole. I didn't impact the nuts. Whole mower only has 6 hrs on it so no beatings replaced.
How far are the blades out ?
Did you try swapping the blades ?
Is the nut on the top of the spindle tight ?
This is a bit on the weird side
whitepony04
There was about an 1/8" difference. I can check the spindle nut tomorrow and give an update.
TJR345
When you measure the blades for level first be sure tires are properly inflated.Next turn the blade so they are side to side.That should be level on both blades (3" for example) Then turn so they face front to back.The front facing blade should be 1/8 to 1/4 lower.
whitepony04
As of right now, everything is tight, blades are within a 1/16 of each under in the center of the deck and side to side the deck is level. Also the front of the deck is about 1/4 lower than the rear.
This is all with the washers installed.
whitepony04
Update: just finished the yard and the cut is better than it's ever been. I rechecked the spindle bolts and they are still tight. Should I lock-tite them?
